Anyone Have Ideas for showing safety wired bolts?
I was wondering if anyone has any good methods to approach items like safety wired fasteners on models and/or drawings
Frank
Frank
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Anyone Have Ideas for showing safety wired bolts?
My motto: Make it pretty and make it once.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
"Node news is good news."
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
Rob Stupplebeen
What do you want to accomplish?
You need a model of a drilled bolt and castle nut. These must show up on your BOM so that you can order them.
I would have to think about the wire. It can easily be modeled with SolidWorks' routing feature and called up on your BOM. You would not be able to re-use the resulting part on another assembly. The next time around, you would have to model it again.
I call up items like threadlocker by inserting empty parts. This generates a BOM entry. You need a note to tell people to use the stuff. You can draw the locking wire on your drawing, as opposed to modeling it. This may be a better way to interface with your MRP/ERP.
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
Safety wire indicated fasteners using item X (wire) IAW Spec ZZZZ
Then creating some simple spec like the one I linked above.
That way you don't need to sketch it everytime in a drawing or create assembly specific twisted wire models through fastener heads.
-Dustin
