Transient analysis of heat exchange
I am looking for resources to help me to determine the time to heat up air circulating in a closed loop by passing it through a fin & tube exchanger where the heating medium is a glycol loop that is picking up waste heat from a generator. Both the air and glycol start out at the same temperature and the generator specs give me the heat rejection and coolant temperature from the engine. I have been tasked with determining the temperature of the air as a function of time.
RE: Transient analysis of heat exchange
Why would anyone want a transient solution?
If so, I will let the administrator decide whether we should offer any further assistance.
In my experience, only steady state values are of interest and vastly simpler to solve; therefore nobody would waste their time to get a transient solution, except for a professor who is teaching differential equations .
I too like some challenges but this one, while easily tractable to me, is not the stuff of real engineering.
Due to the sensitive nature of this work I cannot go into more detail and I've responded in more detail than you frankly deserve considering your rather rude attitude.
TTFN
Now that I think about it the real problem may be a thermal runaway in the coolant unless I can expel the heat after it runs through the coil.
TTFN
I appreciate that you have a problem here, and I can solve it for you using standard equations but why would I unless your company gives me some of it's $1B?
On a more serious note - if this is such a big company then they will have departments of specialists to do this - why are you not using the usual internal departments, or subbing the job out to a consultancy?
Maybe this is a grad question after all..........
Well, if yur company needs a thermal shock solution why would you ask for a time to "heat up air" as you do in your OP? They have nothing to do with each other.
I also strongly suggest that you use the resources of your $1B company or hire a consultant to get the answer you need. And BTW "sensitive military systems" is a joke. If the program is classified, certainly a properly framed problem that requires a solution based on physical theory is NOT classified.
"Unless you can lose ALL the heat generated, there will be thermal runaway, until the generator seizes. I don't think you want to get the air temperature anywhere near that condition, since it'll probably mean that the coolant will be boiling internally within its plumbing, which is a BAD idea."
You're right. The system we are developing is a modification of a system that was originally open loop (the airflow that is). The air was heated by diverting the generator engine coolant (with a 3-way valve) from the radiator to a heat exchanger which - if you think about it - is just another radiator. So we are simply swapping one radiator for another. The problem is we are not blowing fresh air though it anymore but recirculating the heated air. (Ouch).
Thanks - your observation led me to reframe the problem in a way that I can explain the dilemma to my project manager.
Perhaps the key is the control of the amount of coolant diverted for the engine.
There are only 3 possible outcomes:
> Run briefly, off for a LONG time to let the heat out
> Run slightly longer, store the heat somewhere, but eventually, you'll need to shut down for a LONG time to remove the heat
> Run continuously, with continuous heat removal.
Actually a 4th outcome:
> Run continuously, engine gets dangerously hot and melts or seizes.
TTFN
A 1000 gal tank of water with that much heat inflow will start to boil after 7 hrs
TTFN
