SS 316 Sprial Wound Gasket
Dear All,
Can a SS 316 Spiral wound gasket be used in Inconel 625 Flange? Will there be any galvenic action. The application is on a condensate low pressure drain. If it can be used, is there a way for justification.
Thank you
Thank you
RE: SS 316 Sprial Wound Gasket
What is the filler use in the gasket?
What are the physical parameters like temp and pressure?
What Class flanges?
You have some expensive condensate line if the condensate is water.
