AWS Fillet Weld Break Test
I am a CWI, and QA Supervisor, and I wanted to ask for some advice in regards to break testing. I normally have no issues reviewing a break test, but the question has been presented to me about slag line occurring in a break test. My question is, should there be any slag line visible in a break test, weather it be in the weld or along the root pass? I Can see a slag line, but it looks as if it is beyond the root pass, as if it were made due to a slight opening on the tacked side of the break test sample. Please advise.
RE: AWS Fillet Weld Break Test
If I see the square edge of the plate, it means the fusion did not extend to the root. It is for that reason I do not use the edge of a rolled bar as the edge of the butting member. It is nearly impossible for most welders to avoid trapping slag in the radiused corner. The use of 1/2 x 8 inch wide bar stock cut to 4 inch lengths avoids the problem provided your saw can cut straight.
Best regards - Al
He (the welder) is testing himself against a standard to prove to you (and ME! Because I rely on your testing and evaluation judgment)) that he can weld properly.
I strongly recommend, that - if you have doubt about his result - don't question your doubts or try to "paper mache" a rule situation to let him pass. Require a new test.
D1.1 clause 4.30.4.1 is very clear about the required test results. If it didn't manage to bend on itself, then you need to have complete fusion to the root and meet the restrictions for inclusions/porosity at the fracture surface. Something beyond the root is not part of the fracture surface.
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
