Property Tab Builder-Custom Properties
SWX 2010 SP0.0
1) I recently (today) learned how to use the Property Tab Builder, I have created a .prtprp file and can use it in my part files. When I go into a drawing file and hit the Custom Properties Tab, it does not give me the option to select template files that I created and used previously, it just gives me the option to Create Now. So my thought was that I need to create a different custom property template file, not a .prtprp file, for drawings. Like maybe a .drwprp? But I tried to do this in the Property Tab Builder and when I go to save, the only option I get is to save it as a .prtprp file.
I do have my File Location for my Custom Property Files set correctly.
2) Is there a program that I can use to batch add custom properties to a bunch of drawing that have already been created? I used to use a program called Change Properties but that was back in the old days, maybe SWX 2004.
3) One side note, I tried to do a search on Eng-tips for "custom" and the newest posts it finds are from 2007. I just saw a posting from this week with Custom in the title though.
RE: Property Tab Builder-Custom Properties
2) FAQ559-1429: How To Change Or Manage Document Properties And Templates.
3) Use the Google search at top of the page.
The help page doesn't help me with my particular problem, that I can see.
My problem is that I cannot find out where in the Property Tab Builder to select:
.prtprp for parts
.asmprp for assemblies
.drwprp for drawings
When I create the template and do SaveAs the only option in the 'Save As Type' box is the .prtprp.
How can I save it as a .drwprp?
I did find a real cool custom property program that allows me to change alot of files at once. Although I got it off of the UK & Ireland Solidworks site, I can't find it on the US one.
h
Certified SolidWorks Associate
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
For 2), have you looked into using the SolidWorks Task Scheduler?
Steve R.
Thanks! I was clicking in the GroupBox and nothing was happening, but once I clicked OUTSIDE of the Group box I saw the part/Drawing selection option.
49again
I will look into it, but that program I found works perfectly for what I need.
