ERRO:ROTATE NODE
ERRO:ROTATE NODE
ERRO:ROTATE NODE
Hi Stringmaker (Mechanical)
I still have the same problem.but when run file .k appear its:
 TRANSFER SOLID MODEL BOUNDARY CONDITIONS TO FINITE ELEMENT MODEL
      SYMM/ASYM CONSTRAINTS      FROM LINES         =      0
why?????
before I was simulating a analyses implicit ,after a analisis explicit ,only use command symm in analisys implict butnot en explicit.
I do not understand this error....
Thank for the answers.
Add file
RE: ERRO:ROTATE NODE
To be perfectly honest I don't fully understand what you explained above.  In your text file I don't see any errors - just notes.  Are you sure that you have a problem?  If you do try SBCTRAN before solving.
