Revert to ISO from ANSI....
My question, (Strange).  When Solidwork 2007 was initially installed (a couple years ago), it was set to ANSI.  For some reason, everytime I start a new Part, Assembly or Drawing, Solidworks starts as ISO.  I have to go to System Options, change Dimensioning Standard to ANSI (from ISO), and units from MMGS to IPS.
Where do I go to set the DEFAULT of Solidworks to ANSI and IPS units (without using the re-install DVD'?
Thank you in advance.
RE: Revert to ISO from ANSI....
Set your part, drawing and assy templates the way you want them and use these for any new file.
- - -Updraft
