Stress Relief for post molded 6/6 parts
Hi Everyone,
Does anyone have experience in heat stress relieving (post mold) of Dupont Zytel 70G33 (6/6 nylon, black, 33% glass) or similar. We've run some trials and gotten satisfactory results, but plastics are not my primary expertise and I want to make sure we are not shooting ourself in the foot. Cooking out essential ingredients, inducing stress, etc.
Please see the attached profile pic. This is a clamping element for 2 parallel 3/4 inch tubes. Within a week of coming out of the tool, our parts pull the clamping legs closed from stresses. We wedge the legs open, bring the part up to 250 deg F over the course of an hour, soak for 2 hours, cool to ambient overnight. I have all the material props, heat deflection, etc, for this material, but want to be cautious before implementing it into production phase. I don't think we're coming close to thermal degradation at that temp, but I want to float this out to the folks who really know polymers.
Strength tests on our treated parts have shown a 15% increase in breaking strength.
Thanks everyone.
Thanks everyone.
RE: Stress Relief for post molded 6/6 parts
I knew I had seen it somewhere:
http://
Page 29 (actual page number - not PDF number!) - Post Mould Annealing.
According to the above, 250°F is a bit low...
Cheers
Harry
www.tynevalleyplastics.co.uk
I have this document as well. I'm thinking metal, but I don't necessarily want to anneal the part, just relieve some of the internal stresses. Or is this one and the same in the world of polymers?
I'm also wondering if water absorption might actually be the culprit, but here in Minnesota we have terrifically dry air during the winter months. Drying without the wedge won't bring the part back to design profile, either, so I give a low probability to this factor.
Chris DeArmitt PhD FRSC CChem
www.phantomplastics.com
Consultant to the plastics industry
Water absorption is vital to give toughness to nylons - unless the dewpoint in Minnesota is down to -40°C, the nylon will absorb water.
The higher the tool temperature during moulding, the lower the residual stresses and the lower the post-mould shrinkage. Try an oil heater and get the tool surface temperature up to the top end (+75°C) and see if it's any better. (Unless that's what you're doing!!)
A bit late, but where is the feed point? (Just interested)
Cheers
Harry
Harry
We will find out what mold temp that our molder is running at. That is a factor I had not considered.
Thanks everyone.
You can reduce warpage by subtly changing your material and still keep all your mechanicals intact. For example, you can replace some of the glass fiber with mica, or with glass beads to reduce warpage. I saw some recent work using a special silica called NanOsil to reduce warpage in glass filled nylon. You can get information on NanOsil from http://www.nanosilasd.com/
Try boilng (low simmer) a sample for 12hrs and see what happens 24 hrs after that. (Drop one in the office coffee maker) Just a thought.
Chris's suggestion is a good one - assuming you have control over what the material specification. (My personal choice would be one of the partially aromatic nylons from EMS Chemie (Grivory GV3H)) Low water take-up, low warpage, etc etc, and here in the UK anyway, cheaper!!
Cheers
Harry
Dan - Owner
http://www.Hi-TecDesigns.com
No worries, we've got some hot water equipment, as well, so the office coffee will remain safe, and as bad tasting as it always was!
