Coloring Faces
Coloring Faces
Hey guys. How do I make different faces of a part different colors in UG NX 6? I know SolidEdge calls this feature "Part Painter" but I can not find a way to do it in UG. Any help is appreciated.
RE: Coloring Faces
2)select faces, click the 'edit object display' icon from your 'Utility' menu or via the pull down menus <edit><object display>. Change colors as desired and hit <apply>.
There's a bunch of different ways to do this...
SS
CAD should pay for itself, shouldn't it?
RE: Coloring Faces
Edit > object display > select "type filter" > click on face > OK > pick faces you want to change > OK > pick color that you want to change to > OK > OK
I am on NX6
RE: Coloring Faces
RE: Coloring Faces
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
RE: Coloring Faces
RE: Coloring Faces
There are also settings in the system uses to decide how faces of bodies are coloured during Boolean operations to be found under modelling preferences. You may want to address this in your customer defaults as well.
If as a result you get a multi coloured solid that you'd like to make uniform then when changing colours of a solid under the Edit Object Display dialog it is important to tick on Apply to All faces under the settings portion.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
