ScrollArea values help Excel 2007
When I set the ScrollArea in the properties for a worksheet, all is well.  When I save the workbook and then reopen, the ScrollArea properties is blank and scrolling is not locked.  The worksheet is protected.  How do I retain the ScrollArea setting?
View Clyde's profile on LinkedIn
RE: ScrollArea values help Excel 2007
This works, but you have to make a selection before the scroll area is locked.
Private Sub Worksheet_SelectionChange(ByVal Target As Range)
Me.ScrollArea = "E6:R38"
End Sub
Is there a way to have this active when the workbook is opened?
In the Workbook Module, Paste this code:
CODE
Private Sub Workbook_Open()
    Range("E6:R38").Select
End Sub
Make that the "ThisWorkbook" Module...
