Potassium Dichromate?
My company has been asked to recommend one of our specialy hydraulic pumps to pump a solution of potassium dichromate.
I assume that they are referring to a water mixture in the 5-10% range.
What I am looking for:
   1) A reference to compatibility with viton rubber and/or similar materials.
   2) A reference to any of the fluid properties of this kind of mixture (viscosity, density, etc.).
 Thanks in advance to anyone that can lead me to any info.
Remember...
"If you don't use your head, your going to have to use your feet."
RE: Potassium Dichromate?
In relation to Potassium Dichromate with Viton rubber, there is no problem, I am assuming the temperature would be around ambient conditions. Viton is still OK at elevated temperatures about 150C, but the life of elastomer will obviously not be as long. Sorry I cannot help you with your second point.
I hope this helps...............
You can find reference of the solution of potassium dichromate in Perry's handbook .
regards
Huy71
You can find reference of the solution of potassium dichromate in Perry's handbook .If you can't find contact me at tuonghuy50@yahoo.com
regards
Huy71
Chemical supply companies often include an extensive table in their catalogs showing the compatibility of various chemicals with various kinds of O-ring rubber (& sometimes with metals too.)  I'd call Sargent Welch or Malinkrodt or maybe Cole Parmer and ask if they could send you a catalog.
Meintsi,
If there are still fluid properties you need, email me and I'll send you a table of stuff I found.  Sciguyjim@yahoo.com
