Caustic Stress Corrosion Cracking
Does caustic SCC look the same under the microscope as chloride SCC in terms of the spiderweb cracking of stainless steel from chloride SCC. Can't seem to find any pictures of caustic SCC online.
-Mike
RE: Caustic Stress Corrosion Cracking
As to the metallurgical question, I have no idea!
-Mike
What material are you looking at for caustic cracking, a steel?
CSCC in SS can look various ways depending on the temp and strain rate. In SS you will not get CSCC in caustic except for some very rate cases. The high pH usually precludes CSCC.
Plymouth Tube
http://www.hghouston.com/naoh.html
http://www.hghouston.com/naoh_tbl.html
http://www.hghouston.com/naoh_300.html
htt
S
Corrosion & Rust Prevention Control
