No. of Generating Units
We have: Alternative I: Two generating units of 105 MW each initially for total design discharge of 30 cumecs and Net head of 820 m.
Due to transportation constraints of bulky machine, we are exploring the alternative II of having smaller but more no. of units.
So what should be the minimum discharge for each unit? Some standard says 10% while other says (20-25%). Can you all enlighten me on it? I would appreciate.
Good day to you all!
"Common sense is genius dressed in its working clothes." -- Ralph Waldo Emerson
RE: No. of Generating Units
That would seem to be a pumping issue rather than an electric power/generating issue. Did I misunderstand something?
Bill
"Why not the best?"
Jimmy Carter
Does the question pertain to hydraulics of the discharge of multiple turbines?
Alan
"The engineer's first problem in any design situation is to discover what the problem really is." Unk.
Waross and alehman, yeah the question pertains to hydraulics of multiple turbine. In our case, we have multi jet pelton turbine.
Can you enlighten??
You might want to ask the civil/mechanical engineers, rather than a bunch of electricals?
Ok Thanks. I will take my Q there.
Or try Power generating facility engineering. If you start another thread, RF this one.
Alan
