T&G Decking
T&G Decking
Can't find any diaphragm shear values.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: T&G Decking
For horizontal lumber sheathing, values are really low..
RE: T&G Decking
looks like diagonal decking is 6x better than horizontal decking.
now, AITC has allowable roof spans based on simple lay-up and controlled random lay-up for horiztonal pattern. for diagonal allowable spans, do you think it would be as simple as applying a 1.414 factor?
i.e. let's say a particular decking is good for 40 psf over 96" joist spacing with horizontal lay-up. to go diagonal and keep 40 psf you'd have to decrease joist spacing to 67" (96/1.414), or to keep 96" joist spacing the decking would only be good for 28 psf (40/1.414).
also, can controlled random lay-up even be used on a 45 degree?
RE: T&G Decking
thread507-106592: T&G Decking as diaphragm
thread337-254770: Roof Diaphragm - Sheathing over T&G decking
