Simulation on pipe
Simulation on pipe
Simulation on pipe
Trying to do a simulation on a swept pipe profile but I keep getting meshing failures.
I'm pretty new to simulation. Is there some rule of thumb in regards to simulation on pipe members or sweep members?
60% of the time, it works every time.
RE: Simulation on pipe
you may get more responses on this forum:
http://www.eng-tips.com/threadminder.cfm?pid=1183
that being said... try a smaller mesh size.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
Thanks I'll repost there.
Try throwing in some split lines to help guide the mesh.  Sometimes a trivial change in mesh size creates a good mesh all you need to do is have a large enough change to affect 1 edge and the whole mesh will change.  I hope this helps.
Rob Stupplebeen
