ASME Y14.5 - chamfers at degree other than 90
Just to take a short break of radius considerations, I would like to propose chamfer considerations. Please take a look at fig. 1-44 of 1994 standard or 1-45 of 2009 version. Do you think that the method shown on sketches on the left (2 linear dimensions) is OK? I mean, does it fully dimension the chamfer?
RE: ASME Y14.5 - chamfers at degree other than 90
It's not the typical way of doing it for most people, but it works and it's in the standard.
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
You meant Fig 1-46 in the 2009 standard, right?
Both chamfers are unambiguous.
The second chamfer with the dimension and angle is fairly easy to inspect if both dimensions are basic and you use a profile tolerance on the chamfer face. I actually specify stuff like this all the time, although, functionally, the feature never is a chamfer.
As the designer, I would have made the 2X60° chamfer perpendicular to one of the edges.
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
It would make me a lot happier if people would also keep it in mind when I post the odd sketch to try and show a point I'm making on this site.
Anyway, thanks a lot for your quick reaction.
