Seismic Irregularites
Is anyone familiar with a procedure for determining the "story lateral strength" as covered in ASCE 7-05 and more particularly in Table 12.3-2 in ASCE 7-05.
This definition seems very vague to me.
RE: Seismic Irregularites
It depends on the structural system - for dual systems or shearwall systems the concept of story strength is very difficult to define.  For a moment frame type system, you can calculate the strength required to form a story plastic hinge mechanism (for example for steel see the commentary of section C of the seismic specification for a method that would be acceptable for this kind of check - the same basic premise would work for a concrete moment frame as well).
Willis-
Are you referring to the SDM?
Seismic Design Manual - in particular commentary to AISC 341
Yes, I was looking at 341-05, can you point me to a page?
