Ball bearings - Oil Flow Calculation
I have a Shaft on 2 SKF bearings (6005 - Dia25/Dia47/12 and 6207 - Dia35/Dia72/17). Shaft is driven by a dyne at max speed 12,000 rpm. How to calculate the passage oil diameter (in housing) and the oil flow (l/min) for a correct lubrication of bearings ? Oil used is ATF.
RE: Ball bearings - Oil Flow Calculation
http://
(spreadsheet attached)
For diameter see:
http://www.1728.com/flowrate.htm
Then I'd just do a quick Reynolds number to be sure you're well within the laminar range.
http://www
Hope that helps.
