ST Menus will not stay put.
Why do my menus keep changing and moving around the screen?
Does anyone else get this proplem?
In assembly I have the Pathfinder at the far left.
The only tabs on it are Assembly Pathfinder and parts Library.
To the right of this I have the Select menu.
Everything has been saved.
Many times now the Parts Library jumps off the pathfinder and appears below the Select menu, and a Layers tab appears on pathfinder.
I am getting really P'd off with this.
Menu docking was never very good, but this is a farce.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
RE: ST Menus will not stay put.
Jamie
I share your pain.
Sorry for not being of much help.
Patrick
I prefer the pathfinder on the far right, and the rest on the left. depending on the command and environment they move around at random. I thought it was odd.
Sorry to cross thread, but what happened to the escape key exit from in-place edit. This too drives me crazy
Well at least I know its not just me.
I'm also finding that when I Save-As (and this applies to the first save of a new file) the SE window gets un-maximised - by that I mean it switches from full-screen to not full screen.
bc.
Quadro FX4600.
In-place edit, from what I understand by talking to Gtac years ago, escape is the wrong method for leaving in-place edit and can corrupt files. I then asked why it was even an option, of course no response. Looks like the have it "fixed".
We have called in the moving menus to Gtac today... seems like they don't care about that issue either.
Jamie
Jamie
