Reinforcement pad split in half
Whether code allows for split type (Half segmented) RF pad construction.
Regards, Suresh
Regards, Suresh
RE: Reinforcement pad split in half
but A09 has new rules about location of splice and it's NDE
Can you please share broad outlines of requirements for spliced RF pads?
I dont have A09 of Code.
Starrproe
http://www.absa.ca/IBIndex/ib05-004R1.pdf
Unless the provisions given below are satisfied, the area A5 as defined in Fig. UG-37.1 shall be multiplied by 0.75. The area A5 does not require any reduction if one of the following is satisfied:
(1) Each butt weld is radiographed or ultrasonically examined to confirm full penetration, or
(2) For openings in cylinders, the weld is oriented at least 45 deg from the longitudinal axis of the cylinder.
without it you can not do your job
Cheers,
gr2vessels
that was my point
glad to help out guys and do so regularly.
