Reporting Foundation Load - Horizontal Vessels
Is there a provision in Compress wherefrom one can easily pick up foundation loads and moments that can be simply reproduced on the vessel GA drawing?
RE: Reporting Foundation Load - Horizontal Vessels
I suggest you write to Codeware and request the feature.
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
Tom Barsh
Codeware Technical Support
www.codeware.com
I currently have to go through quite a process to take this into consideration.
