Pumps operating with Higher suction pressures
One of the Pump in a refinery plant, is to be selected for operating at Higher suction pressure ( More than 25 bar). What are the precautions / check to be considered while selecting the pump, seal and the Motor power? Thanks to clarify.
RE: Pumps operating with Higher suction pressures
Mechanical seal advise can be obtained from seal manufactureres.
No special consideration for motor power provided it is sized for the pump duty and any upsets likely during operation.
"The problem isn't working out the equation,
its finding the answer to the real question." BigInch
http://virtualpipeline.spaces.live.com/
Johnny Pellin
