HELP ERROR : ROTATED NODES
Hi all:
a question .why when run the ansy/lsdyna appears ITS ERROR:
 *** ERROR ***
 Rotated nodes are not permitted for LsDyna Elements.
WHYYY???
Thank for the answer.
RE: HELP ERROR : ROTATED NODES
Dyna only supports nodal coordinate systems oriented in the global cartesian system, or CID = 0.  If you provide a better description of what you're attempting that would help us to better help you.
Before you solve or write a *.k file in /PREP7 do the following:
CSYS,0
nall
nrot,all
This will correct the issue.  If you need to rotate nodes to create constraints or couples you will need to figure out a work around which is kinematically equivalent.  Dyna has many options available.
Also, it looks like your model is symmetric about the XY plane...why don't you use symmetry?
