Testing Iso Phase
Testing Iso Phase
Sorry I wasn't clear. AC withstand testing between bus and ground. To size an AC test set the power required must be known, 5kVA, 10kVA, etc. Thus the capacitance of the bus, or each length, must be known. Any contractors out there that test it that may help.
RE: Testing Iso Phase
The answer in the other thread is perfectly valid - how do you think the OEM calculates the capacitance? From there it should be easy enough to calculate the size of set you require.
