32"GLOBE ALVE
32"GLOBE ALVE
32"GLOBE ALVE
I NEED 32"GLOBE VALVE DIMENSIONS MOTOR OPERATED DIMENSIONS OR A CATALOGUE CAN ANYBODY HELP ME
RE: 32"GLOBE ALVE
WHOAA ...32"! Boy that's painful!!! Can you step it down to a 30", it'll be a little bit more readily available!?? But your still going to be paying thru the nose on that one. As far as dimension ...at that size, it’s per manufacturer. Good Luck!  ...Mark
RE: 32"GLOBE ALVE
Give me a call, I'll be happy to help you...
 (414) 906-0194
David
-Lakeshore Technical
