Reinf. Conc. Vault for Flowmeter
I need to contruct a concrete vault over an active 30-in PVC C-900 wastewater force main. The flowmeter will be a strap on. My question concerns the pipe/wall penetrations. Because the walls will be poured around the existing force main is it ok for the new concrete to poured dircetly against the pipe or should I make arrangements for there to be some space between the new concrete and the pipe? If a spaace is required, what is a good technique for sealing around the pipe?
thanks
thanks
RE: Reinf. Conc. Vault for Flowmeter
I recommend isolating with Link-Seal or comparable system.
Someday the pipe may need to be "fixed"
http:/
