Water Temperature
Water Temperature
Dear Freinds,
I want to apply Dalton formula to compute evaporation rate from the reservoir.However,I need water temprature data which I dont have on hand.Can you tell me how to estimate or reasonably guess the water temperature from the air temperature?
Dalton Equation,
E=b.v.(es-ea) in mm/d
b wind factor from Figure 4.3
v mean wind speed at 2m height
es saturated vapour pressure at water temperature Tw of
the waterbody(reservoir)
ea actual vapour pressure at air temperature
E evaporation in mm/d
Thank you,
Dalton Equation,
Thank you,
RE: Water Temperature
It depends on the depth of the body of water, lateral and vertical mixing, relative quantities of water (reservoir and inflow), side stream inflow, etc., etc., etc.,...
Very site specific...
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
there is climate data and the evaporation can be computed using other methods such as aerodynamic method.However,I want to compute the evaporation using Dalton Formula for comparison.I am looking for some technical concepts to reasonably guess the water temprature from the air temperature and/or other climate data.
