bolt hole thru weld
bolt hole thru weld
Have a condition where a steel fabricator was permitted to CJP weld a continuous member and because of some changes a connecting beam now requires bolt holes directly thru the weld. Is this prohibited in the code? It's a relatively light connection so my gut reaction is that it would be fine but I've told them that there may be some issues trying to drill a weld.
Any input is appreciated.
RE: bolt hole thru weld
I am not sure of the specifics of the code. Once a CJP weld is done, it is as good as the member. But I don't know if it the same thing as drilling a hole through a member vs. drilling it through weld metal. Do we have to worry about stress risers etc.? I am not sure.
Thanks.
You must also verify that the location of the hole does not cause other issues. Net capacity, residual stresses, etc
ref. AISC Engineering and Quality Criteria for Steel Structures - Common Questions Answered
However, burned holes are technically allowed. If necessary, I recommend burning a smaller hole and reaming to the required diameter.
