filtering in the frequency domain
Hello, and firstly appologies, I am a novice matlab user.
I want to filter some frequencies from a time domain signal (filter out everything below say 7 Hz).  I was expecting to:
FFT time signal to frequency domain
Apply filter to frequency domain signal
inverse FFT filtered signal back to time domain.
What is wrong with this approach? When I plot the results, it seems to have applied the filter to the time domain signal....
Many thanks,  Tom
my .m file so far:
function Hd = tjfilter
Fs = 200; % Sampling frequency
T = 1/Fs; % Sample time
L = 16384; % Length of signal(no. of data lines)
t = (0:L-1)*T; % Time vector
a = load('response_to_z.txt');
t = a(:,1);
x = a(:,2);
figure(1)
plot(t,x)
X = fft(x);
N     = 200;  % Order
Fstop = 7;    % Stopband Frequency
Fpass = 10;    % Passband Frequency
Wstop = 1;    % Stopband Weight
Wpass = 1;  % Passband Weight
dens  = 20;   % Density Factor
% Calculate the coefficients using the FIRPM function.
b  = firpm(N, [0 Fstop Fpass Fs/2]/(Fs/2), [0 0 1 1], [Wstop Wpass], ...
           {dens});
Hd = dfilt.dffir(b);
Y=filter(Hd,X);
fv = [0:0.005:100];
figure(2)
plot(fv,X);
figure(3)
plot(fv,Y);
y = (ifft(Y));
figure(4)
plot(t,y)
RE: filtering in the frequency domain
Hi Greg.
I used the FDA tool to design my filter, then exported it in to my m.file.  The filter seems to work ok, but rather than filtering out the first 7 Hz from my frequency domain signal, it filters the first and last 7 seconds from my time domain signal.  I've mis understood something along the way...
filter() works on time domain data, not frequency domain.  The firpm() function designs a FIR filter to be used with your original time domain data.  I suppose applying it in the frequency domain is effectively modifying the time response rather than the frequency response of your data.  Interesting nevertheless.
- Steve
So just to close the loop for original poster.  Assuming it is an FIR filter.  Then we presume the filter length is 7 seconds on each side of 0 based on symtpoms reported (does that square with the filter length and sample rate?).  Then when we perform convolution of the signal with the FIR we need to start 7 seconds after the beginning of the signal and step 7 seconds before the end of the data, otherwise the filter extends to a region in time where there is no signal.
Sompting guy - Thankyou!
so filter must do the fft - filter - ifft for you.?
If I filter my time domain data, then fft, I can see that the first 7Hz have gone.  This is what I wanted.
Many thanks everyone.  New filter file:
L = 20000; % Length of signal(no. of data lines)
t = a(:,1);
x = a(:,2);
figure(1)
plot(t,x)
X = fft(x);
N     = 500;  % Order
           {dens});
NFFT = 2^nextpow2(L);
r=filter(Hd,x);
figure(2)
plot(t,r);
fv = Fs/L*(0:((L/2)-1));
R = fft(r,NFFT)/L;
f = Fs/2*linspace(0,1,NFFT/2+1);
RA=2*abs(R(1:NFFT/2+1));
figure(10)
plot(f,RA);
You might think about whether a window is required depending on the characteristics of your original signal.
tjakeman:
Filtering is done via convolution in the time domain.  No fft/ifft required.  The help page for filter() explains it all.  Think of a filter as a glorified moving average, with unequal weights on each sample.
- Steve
