Modeling balsa wood properties in Abaqus
Hi, i need to model a composite sandwich structure panel with Abaqus 6.9.2.
It's a T-joint under pull-out testing. The core is made of balsa wood (density 155 Kg/m3).
I have the model finished, but i still have to write the properties for the balsa wood (to get the cracks evolution) and i don't know how to do it.
If someone of you has worked with this material, i would like to be sent the input file.
Thanks in advance!
RE: Modeling balsa wood properties in Abaqus
Thanks Rob, but i already had that information.
I will try now with the other forum smile
Thanks again for your quick answer!
