Configuration Driven feature Dimensions
Hello All
I have recently had a stuff up where I did Pack & go of a sheetmetal part & drawing to make a new part(& drawing).
It is just a U shape part where apart from other diffrences the width of the part across bent legs was diffrent. So I changed the extrude feature dimension in default config. But it didnot change in Flat Pattern config. So the flat pattern did show the old dimension which I failed to notice & the stuff up happened. Just for trail, I tried to change another feature dimension this time a shell feature & this dimension changed in both configurations.
Now My question is how do I know which feature will update in both configs & which will not?
Is there something I am missing in this case?
RE: Configuration Driven feature Dimensions
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
