Hazardous Location Sump Pump
I'm looking for a sump pump for a sink in a hazardous (Class 1 Div 1) location.  Several manufacturers make submersible pumps that are rated for this, but the ones I've seen are too large for this application.  Anyone see any small ones?
---KenRad
RE: Hazardous Location Sump Pump
Try Zoeller - they have pumps (X6160) down to 1/2 HP for Class 1, Div 1.
PEDARRIN2,
I looked at those.  While they would do the job, I was looking for something that wasn't 2' tall, and didn't need a 2' diameter sump.  Hoping to find something that will fit under the sink.  Since I haven't found anything on the Internet, I knew it was a longshot.
---KenRad
Does it need to be a 'solids' sump pump?
if under a sink and just pumping the sink's waste then the passing sphere size could be quite a bit smaller and then you a just looking for a submersible pump.
Hydrae
WHY is under the sink in an explosive environment?
Richard A. Cornelius, P.E.
WWW.amlinereast.com
dicksewerrat - The entire room (where the sink is located) is Class 1 Division 1.  Hence the need for a pump that is rated accordingly.
hydrae - Don't need a solids pump, just a submersible.  Still haven't found a small one for this service (Class 1 Div 1).
---KenRad
