Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have to add my thanks and appreciation for your wonderful site... People who frequent the site are the two best things - nice and smart..."
Geography
terrydraughon (Aerospace)
15 Mar 10 16:09
I am creating part families that have different density parts in the same family.  Is this possible and how do you set up the spreadsheet to do so?
JohnRBaker (Mechanical)
15 Mar 10 17:05
Yes, you can do that.
However, before you start to define the Part Family spreadsheet you have to first assign a name to the Solid Body which makes up your part model.  That can be done by selecting the Body, pressing MB3 and selecting 'Properties', selecting the 'General' tab, entering some meaningful name and hitting OK.
Now when you go to create the Part Family and the initial dialog comes up, under 'Available Columns', select 'Density' and you will see the name which you just assigned to the Solid Body.  Select it and then push the 'Add Column' button.  Now when you open the Spreadsheet (by hitting the 'Create/Edit' button) there will be a spreadsheet column with a title that is the same as the name of the Solid Body and it will contain a value for the current Mass Density set in the part file.  Now if you're working in Imperial Units (inches) this value will be in 'Pounds per Cubic Inch' and if you're working in Metric (mm) the value will be in 'Kilograms per Cubic Meter'.  Now just assign the appropriate Mass Density for each family member, and you should be good to go.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
15 Mar 10 17:26
Thanks John,
I'll give it a try.
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
