Brake disk material
Brake disk material
What kind of steel is used for brake disk? I am planning to get them laser cut, out of 9mm steel plates.(Quantity is only 10)
RE: Brake disk material
Cheers
Greg Locock
http://doc.tms.org/ezMerchant/prodtms.nsf/ProductLookupItemID/JOM-0302-32/$FILE/JOM-0302-32F.pdf?OpenElement
These guys offer rotors with a "limited lifetime warranty against warping." http://www.baer.com/Media/ContentDetails.aspx?ContentID=106
Premium priced "Lifetime" pads are pretty common, but even from big suppliers there may be some FINE print.
http://www.brakewarrantysettlement.com/
What are your thoughts on titamium rotors? ( http://www.zmibrakes.com )
Link to other thread:
http://www.eng-tips.com/viewthread.cfm?SQID=95224&SPID=108&page=1
-Dave
"Everything should be designed as simple as possible, but not simpler"
Of course, a bike would have stainless rotors simply for appearance' sake.
My Corvette OTOH has simple carbon steel rotors, which also seem to work quite well but require grinding on a flywheel grinder rather than a brake lathe when turning is required, because of being too hard for the conventional turning tools.
