Piston length-diameter ratio
Could you help in finding an analytical answer or formulas for a proper length-diameter ratio of a piston to prevent it from binding as a function of force or pressure, and piston diameter, and the clearance between the piston and cylinder bore?  The piston can either be connected to a rod or to nothing.  Thanks very much in advance.
RE: Piston length-diameter ratio
As in a nonguided reciprocating engine piston? Or something similar to a hydraulic cylinder piston? Two very different loadings.
It is something similar to a hydraulic cylinder piston.  Sorry for not making my question clear.  Please help.
