Material for Cooling Water Pump (containing Fluoride ion)
Dear everyone,
I have a question about material selection for cooling water pump.
our cooling water (specific) condition is as follows:
- Temp.: 36 - 46 degree C
- Chloride (Cl-): 2200 ppm
- Fluoride (F-): 2000 ppm
Considering the chloride content, Duplex Stainless Steel is acceptible.
However, I have no idea for effect of fluoride ion in cooling water.
please help for material selection.
RE: Material for Cooling Water Pump (containing Fluoride ion)
Avesta Sheffield 254 SMO® (UNS S31254)can be useful for your application.
lm
I would suggest either a 6% Mo super austenitic (AL-6XN, 254SMO, 1925hMo) or a super duplex (2507, Zeron 100).
I wouldn't expect 2205 to be good enough for this.
Plymouth Tube
What about using a cast iron pump with an internal coating.  Or a bronze pump?   Unless you are set on stainless.
How big a pump are we talking???
StoneCold
In general, F- ions behave similarly to Cl- ions in aqueous environments, so having both species present means that this is a relatively severe environment, even though the temperature is not very high.  I agree with the recommendations by 0707 and EdStainless to use a superaustenitic or superduplex grade if stainless steel is necessary/desired.
There are some problematic issues about using SS.
The shaft alloy selection is one of them, it needs to be at least as corrosion resistant, maybe a Ni alloy such as 625.
One issue with a Cu alloy is the temp and Fl, this is not a good situation for most Cu alloys.
SS would have better erosion resistance.
Plymouth Tube
Thanks everyone!!
