Trouble recording a macro in 2009
We just switched from Solidworks 2007 to 2009 at work. I used to have a macro that would turn off dual dimensions as I don't use them but they are turned on in our drawing templates.
I imported my settings and everything worked except this macro. I tried recording these actions again, but it's almost like the macro feature won't record menu clicks and choices. I know the macros work because I can get them to do simple things like pan and zoom.
I am trying to record this:
Tools/Options/Document Properties and then uncheck "Dual dimensions display"
How can I accomplish this? It doesn't seem to be working.
Thanks.
Thanks.
RE: Trouble recording a macro in 2009
Open the macro for editing
Go to Tools > References
De-select the 2007 type libraries
Select equivalent 2009 type libraries
Exit edit macro
http://fi
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
http://www.fcsuper.com/swblog/?tag=dual-dimension
http://sw
