HySys Vs Aspen Plus?
What is the difference between HySys and Aspen Plus? I have used Aspen Plus for about 8-9 years now, and am currently doing research at a University where HySys has been used to a large degree in undergrad courses. Thus I get this question quite often but I fail to find any major differences... Does anyone have experience of both these programs and any examples of when one is preferred over the other, or when one is not applicable at all?
Rickard
Rickard
RE: HySys Vs Aspen Plus?
Based on my experience, HYSYS is the most user-friendly process simulator. But again, it depends on how much time one has spent working with any software. After going through Pro/II, ChemCAD, Hysys, Aspen Plus - I stick to HYSYS for years.
http://antwrp.gsfc.nasa.gov/apod/astropix.html
I've used Aspen Plus very little. It "looks" nicer, but that's about it. I think they both use the same thermo; version 7.1 of Aspen's suite of tools allows HYSYS to start using the property packages from Aspen Plus. So as far as accuracy goes, you're *probably* going to get the same answers out of both programs. Aspen Plus has solids handling capabilities in it, I believe, and it has an "automatic recycle" capability whereas in HYSYS you have to add them manually. Some folks like that, some folks don't.
What I've seen is folks get used to one simulator, and because of familiarity, that's what they stick with, even if someone shows up with a "better" product, that's cheaper, faster, w/e. It's not so much cost, as it is "this is what we're used to".
Just my two cents. :)
Onwards,
Matt
HYSYS is optimized for upstream oil & gas, gas processing, and refining applications. It has a good workflow centered around 'forward-backward' solving.
