Power Surge Protector 220V-60A
All:
I need to build/buy a power surge protector for a 220V-60A
Double Oven. Or, Plan B, something inside the oven to protect the control/display circuit boards at a lower
voltage/current rating.
Background:
My elderly mother lives alone in rural area prone to
power failures. The last one wiped out her washing
machine and double oven, both with digital displays/controls (expensive!) I wish I could
play a tape of the phone calls to the power company,
and appliance mfr. Any help would be appreciated...
Please keep it simple, I am an ME...Thanks...
Terry
Background:
Terry
The more you know, the more you
know you don't know....
RE: Power Surge Protector 220V-60A
Bill
"Why not the best?"
Jimmy Carter
Ovens are normally connected to 240 V but their controls are connected to 120 V. The washing machine would be connected to 120 V also. Was it just the oven controls that went or the heating elements too?
No blinking lights?
Did you get any response from the power company?
Then have the electrician to install a UL-listed TVSS at the service entrance.
Dave
Thanks for your replies. Further info:
The washing machine has been replaced with analog type.
The damaged oven heating elements were OK, no flashing
lights, and there was 120V power to the circuit
boards.
There was no apparent lightning at the time...there
much wind which blew over many trees/power lines.
The oven was replaced with another with digital
contols/display (against my advice).
The homeowners insurance co. tied with the power
company for laughs at me...
I will have the power company check their ground
and neutral.
I will investigate TVSS's
One other question: Could a splice a standard 120V
surge protector inside the oven in series with
the 120V supply to the new oven circuit boards?
Thanks again...
Terry
