Flange Classes?
Flange Classes?
Hi all,
I was wondering if you could clear up a point with all the various flange classes i.e. class 150, class 300 etc.
Would you be able to explain the difference between the classes and when to use which?? I assume it's to do with pressures and temperatures....
Many thanks
Many thanks
RE: Flange Classes?
After you've done that, come back if you have any more questions.
RE: Flange Classes?
Look at this site and the notes at the bottom of table:-
http://www.scsenergy.com/scsdataflgrating.htm
desertfox
RE: Flange Classes?
Many thanks for the info. Not having ASME B16.5 to hand the webpage you directed me to clears up my initial assumption.
Thanks again.
RE: Flange Classes?
Your welcome
desertfox
RE: Flange Classes?
http://p
pipingdesigner
www.pipingdesigners.com
