Grad Manual PDF
Grad Manual PDF
I have a few FAQ's under a graduate manual. I am unable to post tables and pictures in the FAQ's, thus I am posting the PDF here, as a back link. This manual is given to graduates in my firm with a copy of Structural engineer's pocket book By Fiona Cobb. Please feel free to read and if you do, please make suggestions, or more importantly point out my errors and omissions. This is a live document.
I can guarantee that there are a few errors in the document. Accordingly keep in mind that this paper is only meant to make graduates think, not to solve problems, and should never be used as a reference or similar.
Arguing with an engineer is like wrestling with a pig in mud. After a while you realize that they like it
RE: Grad Manual PDF
RE: Grad Manual PDF
Yes, it can use a little cleanup, but damn...it's good to get those boneheads going on something!!
My respect for seeing the need and filling it! That's what engineering is about. Go Brother.
RE: Grad Manual PDF
Nice manual, I will print it out Monday and go through it. I'll let you know if I see anything that can be included.
I have also been putting together a manual which has included the finer points of structural engineering that isn't commonly found in textbooks or codified to Australian Standards.
Most of what I have written is based on posts that I have started on been involved with here on www.eng-tips.com.
I haven't written on composite sandwich panels that I have been doing recently because I have been flat out with work.
Keep your writings going, there would be a really good market out there if you can write a grad manual that is easy to read and combines all disciplines of structural engineering from technical theory, construction practice and architectural requirements. I love reading material that is written by design engineers for design engineers.
Best of luck.
RE: Grad Manual PDF
RE: Grad Manual PDF
BA
RE: Grad Manual PDF
Keep it up.
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
RE: Grad Manual PDF
A much needed reference, and it should be highly appreciated by not only those starting out, but all ages and levels.
RE: Grad Manual PDF
Poems are made by fools like me, but only God can make a tree. engineers creates wonderful buildings, but only God can creates wonderful minds
RE: Grad Manual PDF
However, if we tell these youngsters everything, they won't need us. Don't we have enough problems with young grads feeling like they know it all? With this, now they really will!!! What's in it for us?
Well, I downloaded me a copy before you remove it and I have to plunk down $150 for the book. Really nice!
RE: Grad Manual PDF
RE: Grad Manual PDF
I don't think that anyone suggested that a graduate engineer plus a good manual is able to eliminate an experienced engineer.
For those lamenting the lack of index, I find the Adobe pdf word search invaluable even to the extent of preferring pdf versions over hard-copies for some documents.
RE: Grad Manual PDF
is adobe pdf word search available in adobe reader?
Cause Ive been looking for it for a while and could never find it.
Also I agree it is a great manual! Wish I had mine that I lent out and never got back.
RE: Grad Manual PDF
I think the word search is available only with Abode Acrobat Standard, not with the free reader.
RE: Grad Manual PDF
http://www.slideruleera.net/contributions.html
www.SlideRuleEra.net![[idea] idea](https://www.tipmaster.com/images/idea.gif)
www.VacuumTubeEra.net
RE: Grad Manual PDF
Asixth,
Nice beginnings of a manual, if you don't mind I will use a few of your topics down the track. Feel free to take any of mine.
Sliderule,
By all means put it up on your website, however if you wait a few days (most probably weeks) I will post a copy with a bit more info and a contents page.
Ron,
The book idea is interesting; I am currently trying to get an FEA discussion paper published by the concrete institute of Aus, but haven't heard back from them, and to think I am offering to give them it for free?
PDF-Xchange is a good viewer for PDF's has a search engine and all.
RE: Grad Manual PDF
On page 26 of your grad manual, item 2 regarding placement of concrete, you write "Never allow the concrete to fall more than 1 to 1.5m meters". Is this referenced in any legislative document. On-site recently we had guys who wanted to pour directly from the truck into a bored pier. Like yourself, our site engineer never allowed concrete to fall more than 1.5 meters because of segregation and likewise the code only says that concrete should be placed in such a manner to avoid segregation. Is this 1.5 meters in writing anywhere that you know of.
RE: Grad Manual PDF
However, I think it is recommended to use tremies to place concrete rather than let it free-fall.
RE: Grad Manual PDF
I was not convinced that the use of elephant trunks was particularly helpful, so in later years abandoned the idea altogether.
I may spend eternity in engineer's hell for having such a cavalier attitude.
BA
RE: Grad Manual PDF
h
RE: Grad Manual PDF
h
RE: Grad Manual PDF
BA
RE: Grad Manual PDF
Good references however I will point out that these fall heights have been developed from testing without large amounts of reinforcing present, such that should only be applicable to massive structures or drilled caissons.
Asixth,
The limit is something I have picked up along the way, I will try and find a reference however.
RE: Grad Manual PDF
RE: Grad Manual PDF
I agree and I shall make the note in the manual clearer.
Asixth,
This is the best I could do, sorry. Page 22
ht
RE: Grad Manual PDF
RE: Grad Manual PDF
RE: Grad Manual PDF
Chaz
RE: Grad Manual PDF
Very nice work. A real addition to the knowledge base on this forum. That's a ton of knowledge and experience in mighty fine packages. It should be required reading by all structural engineers practicing today. And, rather than commenting on your publishing or indexing prowess, we should be grateful for the free gifts; and willing to add to them, if you two will be so kind as to continue your compilations.
RE: Grad Manual PDF
how does this sound?
2.If placing concrete directly from a truck or concrete pump, place concrete vertically into the face of concrete
already in place. Never allow the concrete to fall more than 1 to 1.5 meters, unless you are dealing with massive concrete structures or drilled caissons/pier. For these situations best to talk with the senior structural engineer.
Chaz,
Sorry going to have to say no to this one, for two reasons, 1. I don't use ETABS,SAP,Staad.Pro etc, I use RAPT (on big projects combined with Strand 7 or R/C building), which uses the strip theory, nicely covered by a few books. 2. I don't let my grads near Finite element program until they know the basic's, They are only allowed to use RAPT for checking for the first 6-12 months. I am however writing an FEA paper.
RE: Grad Manual PDF
RE: Grad Manual PDF
27 cu. ft = 1 cu. yd
We are Virginia Tech
Go HOKIES
