ASTM 800, Ferrite content (CF8M)
Three questions:
1. If have worked our the "Volume percent Ferrite" of material ASTM A351 Gr CF8M according to ASTM A800 at 16%. Is there a method of transfering this percentage into a Ferrite number according to ASTM A800? FN?
2. What is the minimum Ferrite percent / FN number possible using the calculation within ASTM A800? for ASTM A351 Gr CF8M?
3. Is it possible to have a ferrite content of 8% or less for ASTM A351 Gr CF8M using the calculation within ASTM A800?
Thanks for any help
RE: ASTM 800, Ferrite content (CF8M)
Answer 1) No
Answer 2) 0% ferrite percent.
Answer 3) Yes, see answer 2).
Regarding 2) and 3), you need to know the niobium and nitrogen content of your steel before you carry out the calculation.
