High Viscosity material- conveying solution
Hi To All,
am working at company that meant to work on new technology which will impact on the current product. this change will increase the viscosity of the material from 10000cp to 100000cp it is look like as plastiline, this product is very sensitive to the tempreature and i cannot dilluite it by other liquid phase (as water).
do you know companies that deal with this complicated material and give solution for conveying?
RE: High Viscosity material- conveying solution
There are number of such companies out there.
http://www.zenithpumps.com/default.htm
http://www.moyno.com/
