Machining of Hastalloy
Does anyone have any experience machining Hastalloy?
if so what Surface speed and depth of cuts are best?
RE: Machining of Hastalloy
The real bugaboo with HastC is that it work hardens and is extremely wear resistant. Keep everything sharp on rigid equipment.
http://www.haynesintl.com/pdf/h2010.pdf
But for the number of holes I needed, I found a hand-held electric punch worked very simple, very fast, and was simplest of all.
Doesn't help you with machining, but I figure I'll throw my 2 cents in.
.220 drill 30 SFM .004-.006 chip load
M6 roll tap 60 RPM
General milling 60-80 sfm
Tin coated carbide or multicoated ticn tialn
Thru hole coolant is very helpfull
