Paralleling VFD outputs to one motor
For capacity reasons can two (or more) VFD outputs be tied to a common bus and then used to power a motor load greater than the rating of one VFD?
Any experiences?
Any manufactures doing this?
Any experiences?
RE: Paralleling VFD outputs to one motor
Did I say "NO"?
Keith Cress
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Neil
All manufacturers use paralleled output devices in their larger VFD's. They typically have 3 IGBT output sections running in parallel. The drive will use a lower current rated 3-phase output "brick" with the 3 output sections paralleled. Paralleling drives can be looked at as an extension of this practice. Some extra precautions are needed such as reactors because of the lead lengths between drives.
Roy
Guardiano
