Need two materials
Need two materials
I was asked a material question today and I remember that you guys are the materials experts! The part will be rubbing on another plastic part made of PEEK, so we'd like the material to be soft compared to PEEK where the PEEK will wear the material it's rubbing against. We're looking to have a disposable and a reusable part made. The requirements of each part are listed below...
Disposable:
Lowest possible heat deflection
Great insulator
Soft material
Lubricous
Iso 10093 biocompatible
Reusable:
Autoclavable
Great insulator
Soft material
May be 2-shot for strength and softness
Thanks a ton!
Disposable:
Great insulator
Soft material
Lubricous
Reusable:
Autoclavable
Great insulator
Soft material
Thanks a ton!
RE: Need two materials
Disposable
Ultra high molecular weight polyethylene UHMWPE
Reusable
POM / Acetal
If Pat and Pud overrule me then listen to them instead. They have actual hands-on experience of such applications.
Chris DeArmitt PhD FRSC CChem
www.phantomplastics.com
Consultant to the plastics industry
Thanks again!
ISO 10093 is Fire Testing....
http://w
H
www.tynevalleyplastics.co.uk
Forgot: Are these parts injection moulded? I assume so as you want some soft stuff.
Also, whatever biocompatibility standard is required, there will be various classifications within it - usually for contact with body fluid times.
Cheers
H
For the biocompatibility, it will come into contact with bodily fluid, so it must be a medical grade.
Thanks, and please let me know if there are any other useful requirements I left out.
Not sure of the autoclaving requirement - most plastics are sterilized by EtO or Gamma ray. 135°C might be a bit high for UHMWPE?
So: further reading for you -
h
UHMWPE moulding flavours (inc medical)
and for softies:
http
There may be others, but these two are my personal favourites as they have excellent technical support (well, in the UK anyway!)
Cheers
Harry
Any grades of PE are subject to softening and deforming under load at normal autoclave temperatures.
At a wild guess from what I think you want, low monomer content nylon 6 might be worth consideration. Nylons are or have been used for suture. Additives to increase hydrolysis resistance, thermal stability and heat deflection (up or down) generally ruin biocompatibility.
PET might also be worth a look although it has limited life when autoclaved as does acetal.
Noryl (modified PPO or PPE) might also be worth a look although I am not aware of its bio-compatibility. It is very good foe bearings in constant contact with hot water.
TPX might also serve your purposes depending on what flex mod and creep resistance you require and on whether or not you can get an alocation. Last I heard it was in very short supply with only one manufacturer in the world.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
As far as the Acetal and PET having limited life when autoclaved, that won't work for the reusable part. If I was to have PPO or PPE mechanically grinding along a PEEK part, would the PEEK be able to survive more so than either of those two materials?
If data is available, Sabic, or your PEEK supplier might have it. Others who may have data are DSM or RTP
Pat
for site rules
Pat
for site rules
http://www.freepatentsonline.com/EP0923945.html
Would you guys happen to have another suggestion for the part to be autoclaved? (If we can get to 20 autoclaves with the material, we'd be happy)
Hardness has little to do with wear resistance when plastics are comcerned....
H
One major factor is the change in properties as temperatures rise due to friction. Another is the change of clearance due to change in temperature.
Skin layer characteristics also have a significant effect as does natural tendency to lubricious.
Pat
for site rules
