Where did CosmosWorks go?
I haven't used CosmosWorks to run any FEA analysis for atleast a year (and even then we were still using SW2007).
Now in SW2010 I can't find it anywhere. Where did it go? I don't see any add-ins for it? Is it called something different?
Is CosmosWorks (or some other FEA analysis tool) still included in SW professional package?
I want to apologize in advance if I have just completely missed something over the past few years.
Thanks for the help.
RE: Where did CosmosWorks go?
Do I need to get a separate Serial Number to install/activate SW Simulation?
Or does it just use the same SN as when installing the base program.
Thanks.
I note you say the "professional package". Please note that in 2010 Simulation is only included in SolidWorks Premium, the only FEA that Professional comes with is SimulationExpress, which is a far more restricted product. Hope this helps.
Joe Hasik,
CSWP/SMTL/MTLS
SW 09 x64, SP 4.1
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
NVIDIA Quadro FX 4600
Thanks for all of the info/clarification.
Check your Add-ins to load the app if you have the correct version of SWx.
I was using SimulationExpress for two months before I realized I had the full app if I checkmarked the Add-in.
