solid state overload trips in spring time
i have an overload for a well pump that acts up in the spring. its a stainless steel enclosure outside. there are three motor starters in the cabinet but only one acts up. It is set at 13.5 amps and the motor draws about 12.4 amps.Last spring i replaced the overload relay thinking condensation was causing problems with the circuitry in the overload. still have the problem. once the weather warms up a bit the problem goes away. any thoughts?
RE: solid state overload trips in spring time
Bill
"Why not the best?"
Jimmy Carter
Bill
"Why not the best?"
Jimmy Carter
Keith Cress
