Re: AISC 360-05 Table J3.4
Steel newbie here--
How is structural steel plate (say 1.25" thk, plan dimensions are ~48"l by 9"w) typically cut? Looking for the method (saw, plasma, laser, others?).
and following on the first Q:
Referring to the middle column of Table J3.4, what cutting methods constitute a "Sheared Edge" condition?
Obviously, thermal cutting is covered in the rightmost column. So, is anything without a rolled edge or cut using a thermal cutting process considered a "sheared edge" (in other words, could the heading of the middle column be changed to "all other edge conditions" or similar?)
RE: Re: AISC 360-05 Table J3.4
For the second question, I've always thought of the third column as the "all other conditions" method. I would put a saw-cut edge in that column.
For 1 1/4" PL the plate is probably gas cut (maybe plasma). 1 1/4" is a little thick for plasma cutting.
No "cutting" method would apply to a sheared edge.
I believe with improvements in the shearing equipment, the middle column will eventually disappear from the spec. (just a rumor)
