WILDFIRE 1 RELATE VIEW
WHERE IS THE RELATE VIEW COMMAND AND HOW TO USE IT?
RE: WILDFIRE 1 RELATE VIEW
It is under edit and you have to to preselect a draft item first.
I TRIED THIS AND DID NOT SEE RELATE UNDER EDIT. DO YOU KNOW WHAT I AM DOING WRONG.
Sorry edit/group/relate to view.
Please stop SHOUTING.
SORRY! Thank you very much. Didn't mean to yell.
whomever invented caps lock should be shot. but assuming that someone is shouting instead of assuming a faulty keypress also doesn't help out. i left out any capitalizations does that mean i'm whisperring?
pro/e doesn't even register differences in lowercase uppercase in file names and usually shows all caps.
Michael
